yea, its hard to move form channel to channel from of your favorite from USA to UK or other country :S
We don't have EPG for India/Pakistan yet. UK,NL,SE,PT,ES,FR are being updated at the moment. US,RO are ok for now.Has the EPG issue been fixed? the only EPG i can see on mag254 is for USA channels no epg on indian / pakistani or UK Channels
check now.We don't have EPG for India/Pakistan yet. UK,NL,SE,PT,ES,FR are being updated at the moment. US,RO are ok for now.Has the EPG issue been fixed? the only EPG i can see on mag254 is for USA channels no epg on indian / pakistani or UK Channels
What about German EPG ? Didnt work yesterday on my test line!
I think it's locked to provider and you can't do anythingHello
I have a problem with a Mag254
i bought it from ebay and yesterday it was here.
But i tested it today it have not the server button on system settings or Portal button is not there.
I tried to update it with usb but it say wrong digital signature i tested a lot of firmwares but nothing from them work.
I hope anyone can help thanks
Hello
rapid doesnt support also this kind of mag device if they find out u are trying to use it they will block it because its not mag but mag emulator
Thank you so much for your comprehensive answer yousif666. That is really helpful.
Thhe lack of ability to schedule a recording is a real disadvantage for me.
How do the streams run. Can you run an hd stream for hours without it freezing?
Hi,Ah yes I get you, load the rapid playlist into siptv then connect mag to siptv portal
exactly ;-)
thats true, it works only with m3u lineHi,
this works only with playlist, if you have portal access, it will not work.
Sorry.
