Channels are working fine so ?Finaly its possible to make a Speedtest with the new update
Anything works wellChannels are working fine so ?Finaly its possible to make a Speedtest with the new update
Ok it's good so, no buffering, it's fine.Anything works wellChannels are working fine so ?Finaly its possible to make a Speedtest with the new update
You can upgrade it manually by usb.It doesn't work for me yet.
It went off last night and my box didn't upgrade as it is disabled for auto-updates. Still on the 'page loading error' in red screen. Any portal refreshing sadly takes me right back to that page again.![]()
Follow this guide https://rapidiptv.com/threads/how-to-check-and-update-your-mag-device.3459/You can upgrade it manually by usb.It doesn't work for me yet.
'Thank you, is there a sticky on here with the files or a guid for that please?
So sorry for sounding such a newbie, and thank you for helping out a damsel in distress
And i precise to download the latest firmware file here http://soft.infomir.com.ua/
You're welcome. After the Update, remember to check if the device can detect New update. If it requests you, accept itAnd i precise to download the latest firmware file here http://soft.infomir.com.ua/
Thank you so much kind sir xx
