But if you want to keep using the sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* portal simply use output=m3u8 instead of the output=ts and it works... ;)
THX THX THX
Your my Hero!!!
I cant belive it .... It works
THX so much
I will edit my Topic to an little Tutorial if someone want to use the SIPTV Portal.
@ Quimic
THX THX THX
Your my Hero!!!
THX so much
output=hls should also work..
Reactions: IgorHabischt
THX THX THX
Your my Hero!!!
THX so much
You're welcome :)
@ Quimic
THX THX THX
Your my Hero!!!
THX so much
You are right the output HLS in the portal is the &output=m3u8 :)
is there any chance i can change the MAC adress from a MAG 254 device? I activated a wront MAC adress :-(
please help me out!!
I have a question
Is it possible to connect an external antenna to MAG 254w2 (wifi)to get better range?
If yes,anyone who has a tutorial how to fix this?
How do i reset tghe mag 254? While starting the STB, it ask for thge password. i have forgotten the password.
When i start my stb, it ask for a password to enter the mag254. i have forgotten the password. can you help? Thanks
EPG for a Polish channels please... On few of them can see some 'pieces' but it's unstable. Regards
the mag get info of the portal adres.
so when we upgrade the portal adres with the new epg and picons. youre box wil get the info automaticlly
in the mean time to work around this:
add the portal link from siptv
portal address: http://mag.sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN *******
and follow this steps:
https://iptv.community/threads/turtorial-smart-iptv.6665/
you will than get the epg form siptv instead of rapid. (only m3u..... links)
Reactions: WarSpaz
When will they upgrade the portal address with the new epg and picons ? We need EPG as soon as possible. I have not see any EPG improvement at all.
All epgs and picons are under construction.
schould be availleble with the dashboard update.
