Yes.. But you dont use the MAC adress you activated ion Sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* on a MAG device . On a MAG device you use a Portal adress provided buy your IPTV provider
My experince is that Smart iptv app works very well, However it really depends on what tv you have.. Exampel: a tv from 2014-15 will not have the best performance . A newer Android TV like my Philips 2017 works like a charm![]()
@Sense:
Which Philips TV model would you recommend? As there are a lot of TV models from Philips.
