So, i'm using smart-iptv-app on my FireTV-Box II. It works very well (minor lags and fast switch-times), but controlling the app with the firetv-remote is a little tricky.
I always wonder, if it would be a better experience for me, to use a MAG 254 or higher.
What do you say?
On my opinion I favour to use on Mag 256 and it works great also the controlling,handling its very easy.
So i mean you can use the Smartv app on the Mag Box also:)
But each Persons have another opinion;)
Reactions: stephanre
Hi there,
the line works good at all, except the channel switching on my MAG 322. It takes mostly about 10 seconds to switch to a channel (especially when its FHD). I dont have the problem on Kodi with m3u. Already tried changing the buffer size. Any tips?
Thanks in advance.
Same problem.
Device returned to seller
Zapping works fine in MAG 254, mag 256 and MAG 352
there is an beta file 2.20.06a3-pub that would fix the audiio sync problem and even faster sapping on mag322. But need to do USB upgrade. Im trying to get the file.
there is a fix a beta file 2.20.06a4-pub but i doesnt have it yet, i hope to get it soon but need usb update.
Hi All
Just got a MAG 322 and it is running incredibly slow on my home wi-fi.
All other devices are fine. Have made sure I’m running the latest software etc.
Anyone else had this, or have any suggestions?????
The box is slow even on ethernet. if you ment channel switching ? that should be fixed in next firmware update
Hi!
I have two mag boxes connected correctly and working url.( checked it)
I can watch tv and suddenly 3-4 Times a Day when i start both boxes i get page load error, check if the url is correct"
Tried to update, downgrade The box, and still The same problem. It works sometimes and suddenly same problem appears.
Any solutions ?
This is the cause of the error..
It doesnt matter really how your feelings are about your device or internetconnection.
Even if you love your device or internetconnection so much.. that wont change the cause of the issue which is:
Internet trouble.
Which can still be caused by 3 different reasons..
1. Box ethernetadapter is unstable
2. Connection trouble (cable . router etc..)
3. internet connection is really interrupted
Reactions: Hitaf
do an usb upgrade with this beta file for mag322
http://soft.infomir.com/pub/.test_fw/324/2.20.06-a6/2.20.06-a6_pub_mag322.zip
pass: 1nf0m1r_test
Insert prepared USB-drive in STB slot.
Enter System Recovery Utility menu; unplugg unit hold meny the button on remote with 3 lines in and put in plug wait for
Select Upgrade tools ⇒ Upgrade Software ⇒ Using USB ⇒ Yes;
Wait until the update process is complete. The info about software update status is displayed in the bottom of screen.
When the software is loaded the STB will automatically reboot.
pass: 1nf0m1r_test
