harryporter
184
45
harryportir
Then use this commands:
non-Tizen TVs (E/F series)
P+/P- and Arrows - navigate pages, groups and channels
ОК, Up/Down - bring up channel list in Play mode
INFO, INFOx2 - show programme information
Number Keys - direct channel selection. "0" - previous channel in Play mode
RETURN - hide channel list and info; go back to primary list; reload the widget
EXIT - go back to widget list
P.SIZE, TOOLS - change picture ratio
PLAY - reload the app (in primary channel list page)
PAUSE - show current stream link in infobar
TTX/MIX - enable 3D mode (Side-By-Side)
AD/SUBT - change subtitles in video (if available)
RED - change Audio track, where possible
GREEN, GUIDE - EPG (Electronic Programme Guide.
YELLOW - show digital clock in Play mode
BLUE - show infobar permanently or change picture ratio (see application settings)
wwe
64
William Elders
Tried everything when I press blue when watching g a channel it goes to one folder contains all orograms it's called client portal
I click that a full list appears but no folders
harryporter
184
45
harryportir
try to use use this buttons P+/P- and Arrows - navigate pages, groups and channels if not post me an sreenshot of your tvs screen
wwe
64
William Elders
Hi thanks for trying to help I really appreciate it
here are my screen shots
Dint kniw now how to upload photo
sorry
wwe
64
William Elders
Ok sorry can't do that I'm on my iPhone
I can't understand why this is not working could it be the way I set up sip Tv I know it's the correct script
wwe
64
William Elders
Any ideas why this won't work for me I'm really frustrated with it I want to ditch my mag 253 from under the telly and use this app but I must have folders working
wwe
64
William Elders
When I press the blue button I get 1 folder called client portal with 4609 channels
not individuale folders with packages in them
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Reset smart iptv app and try to follow my tutorial, using m3u plus link
wwe
64
William Elders
Ok will do will try later as the mrs as now decided to watch TV
LOL
wwe
64
William Elders
hi there are different types of the mu3 file what should the file end with is it MPEGTS OR HLS
or with options
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
or with options
Mpegts is more stable. M3u plus is to have groups per country
Reactions: wwe
wwe
64
William Elders
wwe
64
William Elders
hi does it end like this
=m3u_plus&output=hls
=m3u_plus&output=mpegts
ok I have been using that one with no success so maybe I need to reset every thing uninstall smart iptv and reinstall and start again
will do this when I can get the Tv back
I loaded the correct script reset the app several times but still folders for the channels just a big list
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Reactions: wwe
wwe
64
William Elders
What tv do you have ?
UE55KU6670U series 6 curved
