Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
wwe
64
William Elders
Press on Red button to see what happens
Red buton is audio the other colours do not give folders
Check smart iptv settings, I think there is something wrong with your tv or the application
I don't think it's the Tv it's brand new I'm running smart dns as I have USA apps loaded I got folders before but now they won't load what should the settings be for smart iptv please
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Reset your playlist from your mac adress and upload it again. Try to hard reset settings of smart iptv.
wwe
64
William Elders
Sorry hiw how do I hard reset smart iptv I can do the other hit
TheICF
PremiumIPTV.co.uk
Oct 1, 2016
29
UK
TheICF
i had this last week at a client.
please fo to siptv site and reset playlist , then open app to confirm it has been cleared.
than set playlist again from their website.
if you see the root of the playlist just click on it and you should be inside all groups.
Reactions: wwe
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
Go to Settings of smart tv settings, Smart iptv, clear data, then launch the app and configure it again
wwe
64
William Elders
weldone mate and thank you it's finally working straight away makes Tv viewing so much easier
thank you for sticking with me
wwe
64
William Elders
hi I have Samsung smart tv with a iptv provider already loaded but I want to load another one with out knocking off the first one can this be done and if so how
Cuvillier
Active Member
Feb 19, 2016
327
351
France, FRA
cuvillier
You can upload one list only i think.
Yasser90
How can i create a develop account on Samsung 7series?!
Jamietd
66
22
The best app really for samsung smart is smartiptv
if you would like trial please message me
Jamie
Brakstrom
Im using the Siptv app on my Samsung tv, but this weekend i have to unistall the app 4 times to get the channels to work. I had this problem a couple of weeks ago. It seems that the problem is with the app itself ( works like a charm othewise) But is there someone else that is experince the same problem?
The problem is that it cant load the playlist, no need to reset because it wont work, you must unistall the app itself, then load the list again. And list all your favorites all over again (4 times this weekend) it starts to be annoying....
Someone else that have this problem or have a solution?
Jansson
jansson
I also have siptv on a samsung, but dont have this problem... Do you press "keep online" when u upload your playlist?
Jansson
jansson
this is from the siptv website
2016-10-20
Firmware 1140/42 for K/KU/KS series Samsung TVs
If you haven't done it already, please DO NOT UPDATE! to this firmware version, since it will break the app.
Samsung introduced problems with this update again. Other apps (like Youtube) are affected too.
UPDATE: Samsung has identified the cause of the issue and will try to fix it in future firmware updates.
