Krasse
Thank you very much for the answers. I heard others that have the same problem but after a time with restarts it worked then.
Bvdpas
33
29
Netherlands
I'm using Smart IPTV on my Samsung TV, I've been using the audio track feature lately and it works amazing with RapidIPTV!
The problem is, when i want to select a subtitle track on SIPTV it wont work.
The track is detected by SIPTV, but it wont display. On VLC it does work and display very good.
One of the channels where i tested it on was Nat Geo Wild HD NL.
Does anybody know how to fix this?
JADK
Some Samsung Smart TV only support some versions of DVBS bitmap subtitles, when using the built-in tuner. Maybe Nat Geo Wild HD NL stream uses just that type of DVBS subtitle.
Bvdpas
33
29
Netherlands
Do you know how they get these subtitle tracks? Maybe i can convert it to work.
FreddyK
144
37
32
You could try use TVheadend that convert subtitles so they work in Kodi.
That maybe works for SIPTV too.
TVheadend can export m3u files you can use.
rayon011
Belgium
rayon011
hi I have Samsung smart tv with a iptv provider already loaded but I want to load another one with out knocking off the first one can this be done and if so how
Hello, u can upload another iptv provider , i do it for my customers, i've 3 pannels :)
when u download the first iptv provider add with plus button (green) the second link... and all the channels will be uploaded .
RD71
33
friend got the same problem on his samsung tv and smart iptv , just vod chans, iptv works fine
Ben Zenga
I have the same problem. Unfortunatelly on all VOD. Any idea how to fix this? Edit: Samsung KS8080
losmighty
Am i the only one who got problem with siptv ( samsung smart tv) since yesterday ...
Its laggy , its slow , its load the channels reall really slow , it responds really late when i switch or try to go back to groups can someone help or is it problem by siptv ?
Rusax
Let me show you the world
Feb 4, 2017
576
743
www.rusax.nl
Rusmir
Try to delete the cache from youre Tvs memory, the tv has not as much memory like a box.
also change the buffer time to 0. so you dont use the memory
Dutch IPTV reseller
~~~ Let me show u the world ~~~
www.rusax.nl
