Im new subscriber with VIPTV.TOP i pay 20 US dollar for / 1 Month and i need the Channel list on my Smart IPTV Samsung
can any one help me ????
Sincerely no but when SMART IPTV app is making problems best way to understand if its app is to deinstall it turn off tv from electricity for 5-10 minutes and then reinstall. Resolves different isues maybe this is also a case.thanks for the reply Harry, is this something you have come across before?
try turning of the artificial Motion settings on your TV in most cases you should notice better playback
Press the MENU button on your remote to display the menu. Press the ENTER button to select “Picture” and turn off auto motion plus. This has worked wonders for those having slight glitch or stutter during motion scenes.
or try go back to the TV viewing and then into Menu -> Smart Features and now 'Clear viewing history' is enabled. I guess some can't clear it while it's loaded for some reason.
otherwise i dont know
- Have you pay the Smart iptv app? ( for 7 days are free after you must to buy )
- Sip******* WARNING FRAUD **DON'T BUY** PLEASE REPORT TO ADMIN ******* have you make any changes? Put agian on this site your MAC adress also the ULR and restart the app
- If there no help you then deltet the app and install again and follow the same way how Step 2
Check if works
