Alaa86
Hi ,
Please try with 4.2.2.1 dns ip adress it should resolve your problem.
Savke3
Jop its treu , i have by new model Samsung Q7Fn 2018 and i dont have samrt iptv app , only Smart stb
Zaidinho
I have a Samsung J5500 smart TV, and SMART IPTV was working fine. But since yesterday, it crashes just before loading the channel list.
If anyone have an idea about how to fix this issue or about the cause please help.
Thanks in advance
Reactions: Racon
Andrei Zeve
14
36
Thanks in advance
Did you try to load an empty list to see if your application starts?
Reactions: Vlad Nicolae
Zaidinho
Thanks in advance
Not yet, but I will try it.
However, I can abandon the channel loading by clicking on '0' and I can access to the app menu and settings ... So the app is working.
I am suspecting that the problem is related to the app last update, because auto update was activated on my tv, and I have remarked on the smart hub that the date of the last update of smart iptv is the 23 july, the date when the problem started.
tavaresj
tavaresj
They were undergoing maintenance this could of caused the issue.
Armand Henny
Samsung
Thanks in advance
In de instellingen pagina houdt hij ook het vinkje van "Load Primary Channels list" niet vast. Ik denk dat dit ook te maken heeft met de update, intussen 3.0.83. Wie heeft de oplossing?
MaGUK
20
UK
margaspar
Uninstall the app and reinstall. Since the mac is the same, it will be activated so not to worry.
Upload the list again.
This happens sometimes as the TV cannot delete all cache.
MaGUK
20
UK
margaspar
If you have the icon on the recent ones, use the up arrow and it will appear a bin (and a pin). Use the bin, confirm delection and then reinstall it.
