Ended up doing a full factory reset on the TV. After that I reinstalled the app and I'm up and running again.
Thank you!! After resetting my Samsung TV it is working better now.Hello,
- which m3u link (with options) do you use MPEGTS or the HLS link?
- try to use MPEGTS eg to see if it works better.
- Additionally, try reducing your playlist size by removing channels/movies (Dashboard >> Bouquet List)
- You could try to change the pw of your m3u link thru your dashboard and upload link again.
- Delete the app from your Smart Tv and then reinstall again. (Additionally, try to reset your Samsung TV)
- Or even try to restart your router and wait for 5 min and try again.
- Change DNS, on your TV, Press the “Menu” button on your remote.
- Under “Settings menu” select “Network” (1) then choose “Network Status” (2).
- After several seconds you will see 3 buttons. ...
- Choose “DNS setting” (4).
- Select “Enter manually” (5).
- Enter the SmartyDNS DNS addresses (6).
- Cloudflare DNS: 1.0.0.1 or 1.1.1.1
DNS Watch: 82.200.69.80 or 84.200.70.40- some routers have safe DNS option that is forcing router DNS even if you put custom dns on other devices so first thing to do specialy for Vodafone is to disable SECURE DNS in Router internet settings.
Hello,Hmm Still same problem.
that must be an issue with TV... did it work before or are the VOD not working since the first day?
Did you try to clean the cache of your tv and tried to change the DNS?
- Under “Settings menu” select “Network” then choose “Network Status”
Yes, I cleared the cache but did not help at all. I‘ll try again after changing DNS. Thanks!
Read Check AgainThanks for your answer. I've deleted the playlist, restart and upload a new one, ending by type=m3u&output=m3u8, but the groups are still not there :/
