Output=ts not better than output=m3u8 ?
=ts should be used if your internet speed/Router can handle it , However = M3U8 uses Pre-buffer wich may give a more stable connection to the servers'Output=ts not better than output=m3u8 ?
Hello,Hianybody an idea, why i can't access to channels anymore? i am getting check playlist url error. It was working fine until today. I've already checked playlist on my smartphone and it's working on it. I've also unplugged TV cable for 1 minute. Also deleted playlist and uploaded again. But it still fails.
please remove the Smart IPTV and reinstall again then upload the channel list and try.
please try the line using different DNS. Here is the Setup guide: https://iptvhelpcenter.com/r/how-to-change-dns-on-different-iptv-devices
Cloudflare DNS: 1.0.0.1 or 1.1.1.1
You need to contact your reseller to reset the line, means change the line Password.
I have a huge mysterious problem. My SIPTV does not load any channel. It still loads the example list though.
IPS: UPC Austria
Here are the steps I've tried so far;
- Smart HUB and Factory Reset
- Shortend the bouqouet list
- Tried both m3u with options
- Re/De/Installed Smart IPTV App a dozen times, rebooted TV a dozen times
- Tried via iPhone 4G
- DNS Changes
- Rebooted IPS Router
Line working fine. Tried it using VLC/Kodi/Perfect Player. But it just wont work on TV...
Best regards,
Xnatur
I have the same Problem my ISP is UPS Austria too
Yesterday all was working like a charm suddently black screen and when i press on a chennel it only says Connecting....
Did all what Xnatur did but nothing worked.
did you change the DNS directly on the router? if not try that.
